The aim of this game is to press the corresponding pins pointed to by the arrow in the LED.
programming
Programming is done in the MakeCode Editor, no extensions are necessary.
- The variable “SpielStart” is needed to easily start and end the game.
- One of the 4 pin functions is always called at random to call up the arrows alternately.
- The arrow always points to the pin that must be pressed as quickly as possible.
- If you press the right pin, you get a point, if you press the wrong one, a point is deducted.
- To display the score on the LED, you need two variables X and Y and the drawing block from the LED's category.
- Variables ensure the correct display of points on the LED, especially minus points.
LED-Matrix
This is how the matrix for LED block X and Y is structured.
